Unable to add device to MDM
adamw1
I have not had an issue with this before so I suspect something has caused this issue. After using Apple Configurator to prepare an iPad (nothing changed there) after doing so only a week ago with several others, the iPad is saying that the configuration for the iPad could not be downloaded.
Operation cannot complete because of NSURLErrorDomain error -1012
I have tried this on the companies WiFi as well as on 4g so there is no block in place. I have reset the iPad twice and can confirm this also is not the issue.
The connection to n46.meraki.com replies with an HTTP status of 0 according to our smoothwall device although I can ping the address which currently resolves to dal297.meraki.com
Any suggestions?
adamw1
So,
I think the certificates have all changed. Now I have reimported an MDM mobileconfig file, its back up and running.
11 Replies 11
nealgs
It appears to be an Apple App Store related error rather than Meraki.
Definitely an -1012 error code?
adamw1
Definitely a -1012 error code on the iPad 2 ON the screen which asks if you would like to install the profile from the MDM (i.e. Remote Management). An iPad air had a slightly different display:
It said "cancelled"
Just as a note, the iPads are COMPLETELY wiped and are literally only getting prepared with Apple Configurator.
Richard_W
have you updated Configurator?
adamw1
Thank you for your reply, I will have a look and see if there are any updates. Has there been a change in how iOS 12.4.1 (which built fine a few days before) deploys MDM? Or IOS 9.3.5 for that matter which I should have stated originally.
EDIT:
The mac I am using is as up to date with configurator as I can get it. Configurator is version 2.7 (3H96)
Richard_W
FYI Configurator is at 2.10
adamw1
Thank you, that's what you get when your lumbered with a 2010 macbook stuck on high sierra...
Either way, still works!
adamw1
So,
kylexmather
By "I think the certificates have all changed", I'm unsure of your setup but we use an SSL cert given to us by our ISP. I usually import that same cert file locally as a profile using configurator to fix the problematic devices - this has since stopped working. I was think of asking our ISP for a fresh cert. Is this a similar scenario to yourself?
adamw1
Hi kylexmather, the issue was the MDM certificates, not any of our SSL certs. I updated it by downloading the latest MDM mobileconfig file from meraki and reimporting it to configurator.
Hope this helps.
Richard_W
kylexmather
Right, I shall give that a try!
