Thanks for the reply...
So the Sentry VPN solution only provides automated VPN configurations, regardless of the VPN client (embedded in OS or separate app).
So the SM is not going to provide much difference in VPN solutions, just automation.
This means Meraki only supports Anyconnect VPN client as the only straightforward solution.
This is even not suitable for Linux distro's at the moment.
In short, I rather use a third party VPN solution than Meraki owned solutions.
Are there any statements here which you do not agree with?
Thanks to comment
Peter
