So it is only possible to enable the cellular payload for the APPs on iOS?
What about Android?
And if i choose an APP on iOS Network Usage Rules, and disable "Allow Cellular Data" so its impossible to use the APP without Wifi or can we use the APP with Cellular but only Updates per Wifi?
Thanks in advance.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
