System Manager API Device Scope By Tag
wperry1
Based on the documentation here, you can query devices by tag scopes but either it doesn't specify or I am misreading how to specify the scope.
The field description says
Specify a scope (one of all, none, withAny, withAll, withoutAny, or withoutAll) and a set of tags as comma separated values.
so it should be something like scope=withAny, but then what? Where do you list the tags to query?
Thank you in advance for any help on this.
WP
VictorM
Meraki Alumni (Retired)
Hey WP
You can include the tags after the scope descriptor, separated by a comma.
So, for example, if you wanted to return all devices with any of the tags "engineering" and "hq", you'd do:
scope=withAny,engineering,hq
For any devices without any of the tags "compromised", you would do:
scope=withoutAny,compromised
etc.
Hope this helps!
2 REPLIES 2
VictorM
Hey WP
etc.
Hope this helps!
I'm a little embarrassed I didn't think of that. I tried a colon, semicolon, and space (%20). It didn't occur to me to use a comma.
Thanks for your help.
