Single App Mode and no Wi-Fi
Ulysses
Is there anything I can do if I am stuck in Single App mode and Wi-Fi goes out?
jared_f
@Ulysses Is this device DEP?
Ulysses
@jared_f No, these were setup through Apple Configurator 2.5.
jared_f
@Ulysses Good, that will make it a lot easier. Plug the device into Apple Configurator, go to profiles, and then delete the Meraki Managment Profile. This will remove the app lock.
Make sure you navigate to m.meraki.com to re-enroll the device after. During the enrollment, it should refresh inventory and remove the app lock profile (assuming you removed the device from the profile / lock in Dashboard).
Jared
koen
I have the same issue but the device is DEP. What can I do?
