We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I am trying to set up the self service portal. I select Enable SSP for this network. When I save changes I get the error "Default Device limit cannot be blank", but there is no option to set a limit
I'm in the same situation, but this is several years later. Is there a known fix for this?
Default device limit is under Trusted Access in Systems Manager > General :
Set this first, and save, then configure your SSP settings / enable
