Hi !
We set up a new Windows 2019 domain controller and wanted to install the SMAgent (3.1.1) on this machine.
Now the setup fails with the following error:
Network connectivity is give, nothing is filtered.
I wrote a packet trace and saw that the client connects to ios.meraki.com and presents a user-certificate from the local CA.
This causes an Encrytion Alert and terminates the session, thus resulting the SMClient noch to connect.
We discovered that windows authenticates with the certificate of the user.
So we logged on with a service user and installed the SMClient and entered the network id which now worked fine, BUT:
The client does not show up in the clients pane in the dashboard.
Does anyone have any idea on how to install the client correctly or how to get around this issue ?
