SM Legacy - Feature disabled by default for Privacy
Firebits
I can no longer access the Command Prompt or Remote Desktop on a new network.  Instead, I receive the error "This feature is disabled by default for user privacy. This can be enabled under the 'Feature restrictions' section of the general settings page."  When I click on the link to General Settings there is no Feature Restrictions section.  Any ideas?
Accepted Solutions
Firebits
Re: SM Legacy - Feature disabled by default for Privacy
Found it!  Systems Manager > General > Feature Restrictions > Disabled features.  The message that comes up names this as under Privacy which does not show as this on SM Legacy.  All working again **phew!**
5 REPLIES 5
Roska
You´re using the free 100 SM licenses offer still? I suggest a move to a paid subscription.
Firebits
SM Legacy does all I need it too, and the quotes I've had For Meraki are double what I'm getting elsewhere for what Legacy is sufficient for.
Roska
Interesting, having worked with various MDM providers Í really feel Meraki is really good price / features ratio in the market. Would be nice to hear what you´re needs are and what vendors have you evaluated.
Nevertheless the Free 100 program has been discontinued two years ago already.
https://meraki.cisco.com/support/#policies:smfree100
Hope you get your issues fixed.
Firebits
I wasn't actually ever on the Free 100, I've been using it for so long it was in pre subscription days!  Still, jumping up from £0 to £6,500 per year is going to take some justification.
Firebits
