Read & Write Keyboard for IoS
Jordanw
Hey Everyone, I was wondering if anyone out there knows how to switch the keyboard on IoS through SM.  Specifically I am tying to get student ipads in our K - 12 District to default to the Read and Write keyboard.  Any help would be super appreciated.
@Jordanw  I have done a bit of searching and I cannot find any settings to specifiy a particular keyboard layout. Apple like to let users still have some control of a manager device.
For example you can set the requirement to have a passcode however you cannot actually specify the password that is to be used.
5 REPLIES 5
BlakeRichardson
@Jordanw Usually user settings like that cannot be controlled on iOS devices using an MDM.
That is very very heartbreaking
Which is kind of backwards in an enterprise environment?  If I had a time machine I would be abandoning all iOS devices for our district.  It's just too much.  Thanks for looking out.
Noah_Salzman
Meraki Alumni (Retired)
Just to clarify, when you say "Read and Write keyboard" do you mean this:
https://apps.apple.com/us/app/read-write-for-ipad/id934749270
