Hi PhilipDAth, thanks for your quick reply 🙂
"how could a CSV import work to associate a tag to a device (or are you referring to user tags)?"
-- That's why I call them "Predefined Tags"; predefined by Systems Manager so you can update them accordingly.
E.g.: Mobile Device Name = blank, Room = blank etc.
Why do we need this? So can we update my school's 200+ student iPad's "Mobile Device Name / Department / Building / Room" using a CSV. Jamf can't do that alone, we'll need MUT for that to work.
For my 1:1 iPad school's Jamf setup, each classroom have their own set of apps. If an iPad belongs to Room 20, it'll get Room 20's app. I can get the same result using tags in SM at the moment so that's all good; only problem is at the end of the year, I need to update 200+ iPad details manually because students have moved up a year / moved on from the primary school. Before MUT comes along, I had to do this manually for each iPad, but with MUT, I can use update a CSV file and ask MUT to update the "Mobile Device Name / Department / Building / Room" accordingly; I can update all of the student's iPad in a few seconds. I was wondering whether this feature will be useful in SM so System Admins can update iPad info easily rather than do it one iPad at a time.
"You might be better off using the "Notes" field. You can update this via API (instead of using CSV) using this API call:"
-- Sorry I'm not much of a software developer myself.
