https://documentation.meraki.com/SM/Profiles_and_Settings/Configuring_an_Exchange_ActiveSync_Profile
You'll still need to authenticate each iPad manually, but the above should help
Thanks. What I'm looking for is a way to do this through MDM. Settings->Calendar->Accounts->Add Account->Microsoft Exchange
The Outlook is already setup with their login so the device shouldn't need authentication again, just their email.
If you are using Outlook, then you would need to enable the option in Outlook to also sync the calendar.
I don't know the answer, but you would need to find what options you can push to Outlook for iOS.
I just need to know how to add and existing office365 account to the calendar app via Meraki's mdm. Whether it be by a policy or something else?
Refer to my post above on how to add an exchange profile
But you will need to authenticate again. That's unavoidable
