My MDM certificate is about to expire, but I no longer use it.
timmy-zhou
我收到一封电子邮件,提示我:
YouriOS MDM APNS 证书将在大约 1 个月后过期。过期后,设备将无法注册,并且 Systems Manager 无法联系客户端,直到续订证书。
但是我不再使用这个功能了,证书过期后会影响我的网络吗?我需要做些什么来避免由于此证书过期而影响我的网络
2 Replies 2
If you don't have any devices under management then you don't need to renew the certificate.
FeliA
Hello @timmy-zhou,
As PhilipDAth mentioned, this message regarding APNS certificate renewal can be safely disregarded if you no longer have need of this feature and no longer have any iOS or macOS devices enrolled in Systems Manager.
However, if these devices are still enrolled and are required to be managed in Systems Manager, you will need to follow the steps in the documentation below to properly renew the APNS cert every 365 days:
https://documentation.meraki.com/SM/Device_Enrollment/Apple_MDM_Push_Certificate#Renewing_an_Apple_M...
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
