- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Multiple Profiles - How to Enroll a Device
Good morning,
In the company I work for, we have several Android mobile devices, totalling 60 units. Not all of them need the same configuration, so I have created two profiles. The issue arises when enrolling a device, as it automatically adds to the default profile and does not allow me to choose the desired profile. Is there a way to enroll a device and specify which profile I want it to install? Currently, what I do is enroll with the default profile and then change the profile in the device settings later.
Thank you very much.
Solved! Go to solution.
- Labels:
Android
Enrollment
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can change the profile after the device has been enrolled.
https://documentation.meraki.com/SM/Profiles_and_Settings/Configuration_Profiles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In the past when I have had quite different device needs - I have actually created separate Systems Manager networks. For example, BYOD and Corporate. I find it makes some of the policies easier too.
Then you can use two different enrollment URLs/QR Codes, etc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello. Thank you for your response.
