Is anyone else having issues with the Meraki MDM App not working on iOS 13.2.3? I'm getting widespread reports from my schools having issues with the App not working.
I was able to replicate the issue:
I'm opening a case with Meraki soon as this has an iPads that are reset non-functional
@Noah_Salzman Do you know of any issues?
Solved! Go to solution.
Hey @WesCarlson , can you confirm that v2.5.4 of the Meraki iOS app is installed? That version should have fixed the issues introduced in 2.5.3.
I'll dig into this and get back to you. Thanks for reporting this.
@Noah_Salzman I was able to replicate it on iOS 13.1.2. On hold in the support queue right now.
YES! This was my first device enrollment with newly configured DEP settings so I thought it was my mistake. Glad to see that this is not only my problem. Thanks for posting!
@DeanPoirier Meraki support is saying there is an issue with the new version of the Meraki MDM app that was pushed out and they are working to resolve it right now.
Thankfully I had an iPad lying around iOS 10.0.2 which helped them know it was more than the dark mode of iOS 13 causing the issues.
All: this issue is being worked on right now and is considered high priority. We'll update this thread once we can share an ETA on a fix.
Thank you. I have several dozen iPads (iOS v13.1.1 - iOS v13.2.3) waiting to be deployed.
@Noah_Salzman From what I have seen the v2.5.4 has fixed the issues we have seen.
