Mac Application installation detection issues
jhuyck
Had to create a custom DMG package for installing SentinelOne on Mac. It installs properly and all works, the only issue is that Meraki does not see it as installed. Is there a way to tag what meraki should look for when an application is properly installed. It sees the application in the list of installed apps with the proper version, but it just keeps showing as missing.
jhuyck
Well just solved my own issue, by realizing I needed to have the proper name for the application so it would match with what was installed. Thanks to @Shany for putting the link in another post.
Installing Custom Apps on Windows and Mac Devices - Cisco Meraki Documentation
1 Reply 1
jhuyck
