Issues on Updating Apps on iPadOS 26+ and 18+
DocRT
Just browsing
Hi there,
we see currently on all our managed iPads following errors, while SM is trying to install app updates:
Code: 1005
Domain: DeviceManagement.error
Error: App konnte nicht installiert werden. (Translation: Unable to install app)
Error: Unhandled exception
Are there any known issues in relation to the Appstore, Meraki or anything else which can prevent te installation of app updates?
Thanks a lot!
2 Replies 2
KFoster
Ensure VPP has enough licenses to deploy the apps in question. Sometimes you need to run the reclaim process using the "Revoke unknown device licenses" option
DocRT
Just browsing
thank you for your reply. I don't think that this is a license issue. On Monday this week the app update process worked again, yesterday got some trouble again. Very strange, but also maybe related to connectivity since students are roaming around.. Will keep an eye on that.
