Is it possible to enable Lost mode on multiple devices?
AkeMalmgren
About 30 iPads were stolen from work. Can I enable Lost mode with the same message on all of them, without typing it in and pressing Enable on every device? Can it be enabled using a tag?
1 Reply 1
jared_f
@AkeMalmgren I don't think so. Are your iPads DEP enrolled? If so, remove authentication and see if you can get them pinging Meraki again. You could forward the IP address and location to the police. While you could start restricting the device with a profile, try to make it as transparent as possible not to tip them off!
