Include Tagging in DEP Enrollment
jared_f
Hi All!
From my understanding you can tag individual devices before they go through DEP and they will receive the appropriate settings. But, is there any way of including standard tags within that DEP settings tab so I don't have to tag each devices and/or mass select devices to tag?
Thanks!
Jared
6 Replies 6
Could you use the "Default Tags" option under "General" ?
BlakeRichardson
Ah you bet me to it, @PhilipDAth has just suggested what I was going to suggest. I don't think these tags apply to everything, I have only ever seen them apply to iOS devices not any other devices added to systems manager
I can't imagine @jared_f having any non Apple devices.
jared_f
Lol... that is my specialty!
BlakeRichardson
Ok what has been suggested won't work upon further investigation.
PeterJames
@BlakeRichardson Ah, but this is where the plot thickens...
You can pre-apply tags to DEP devices before they are enrolled. This can be done at the same time you apply the Core DEP profile settings.
(However if you are taking the Apple COnfigurator 2.5 / iOS11 manual enrolment route you will need to do this after the device shows up on the list.)
Thank you,
Peter James
