INSTALL_FAILD_INVALID APK - Meraki Systems Manager.
Uglee
I have been trying to add a Custom App on Meraki Systems Manager Dashboard, but the app cannot be installed on the android devices when I push it. It keeps showing INSTALL_FAILD_INVALID APK. Has anyone faced with this issue before? Kindly provide the necessary steps on what should be done next to have the apk file installable.
Thanks...
ConnorL
Does the APK you're trying to push install correctly if you try to install it manually? Invalid APK to me sounds like it's either corrupted or you've referenced the wrong App Identifer.
Uglee
Yes, the APK file install correctly when I try to install it manually on the devices. It's only showing the error message INSTALL_FAILD_INVALID APK when I pushed it using the Systems Manager.
ConnorL
Mind dropping me a DM with a link to your Dashboard, specifically the app itself. E.g.
https://n736.meraki.com/NetworkName/abcdef1234/manage/configure/apps/64514.....
Are you sure the app ID is correct?
