How to "Auto Join" using Sentry Wi-Fi
MSCICT
Just browsing
We have both Meraki MDM and Meraki access point. I'm trying to get a windows tablet to automatically join to our Meraki WiFi network using the "Systems Mananger Sentry Wi-Fi security" feature listed on the SSID Access Control page. It works, but the problem is it doesn't automatically join the network.
I notice that if I create a Wi-Fi profile manually under Meraki MDM, there's a checkbox named "Auto Join". This isn't available on the profile automatically created by the Sentry Wi-Fi feature.
Does anyone know if it's possible to have devices auto join Wi-Fi using the Sentry Wi-Fi security feature?
Cheers,
Tom
2 REPLIES 2
Pulkit_Mittal
Re: How to "Auto Join" using Sentry Wi-Fi
Hi @MSCICT,
Right, I believe this is the way, as mentioned here https://meraki.cisco.com/blog/2015/11/set-and-forget/
Thanks!
ConnorL
Hey Tom,
You'll just need to tick the Auto Join box. None of the fields are 'pre-ticked'.
This is pushed to my iPhone for example, and whenever I am at home (not that we've been allowed to leave with the current lockdown!), it will automatically authenticate with the network.
Kind regards,
Connor Loughlin
Network Support Engineer
.:|:.:|:. Cisco Meraki EMEAR 🇬🇧
For reference, many questions can be easily answered by searching our online documentation: http://documentation.meraki.com
