Help removing default app on IOS
TheBarge
Hi, Good day! is there any way to remove default app on IOS profile globally? specific to Translate and Magnifier. Thanks in advance
BlakeRichardson
@TheBarge hiding apps using a restriction payload is the way to do this. We hide an awful lot of the default apps.
6 Replies 6
MatthewFrey
I have the same question  -  I use restrictions to remove all the default ios apps -  but "magnifier" isn't on the list of apps to remove -  I'm sure this just needs added to the choices.    Translate is in the list of removeable apps.
MatthewFrey
Oh - -  I think I figured it out,  just type com.apple.magnifier into the Show or hide apps box in restrictions
I'll try this one thanks a lot!
BlakeRichardson
TheBarge
Sorry for the late response I appreciate this. Thanks a lot!
leoa69
Thanks everyone for information.
