Hi, Good day! is there any way to remove default app on IOS profile globally? specific to Translate and Magnifier. Thanks in advance
Solved! Go to Solution.
@TheBarge hiding apps using a restriction payload is the way to do this. We hide an awful lot of the default apps.
I have the same question - I use restrictions to remove all the default ios apps - but "magnifier" isn't on the list of apps to remove - I'm sure this just needs added to the choices. Translate is in the list of removeable apps.
Oh - - I think I figured it out, just type com.apple.magnifier into the Show or hide apps box in restrictions
I'll try this one thanks a lot!
Sorry for the late response I appreciate this. Thanks a lot!
