Hi @beks88 ,
In expanding the answer by @sshort; Page 77 of the Apple MDM Protocol documentation states that the install later command is only available for MacOS.
MDM Protocol Documentation
If you really need to do this, I would:
- Day 1 morning remove any lock requirements and push 'Clear Lock' on all devices (individually)
- Day 1 midnight push iOS update
- Day 2 Re-apply the lock profile to force a new PIN is set
However, if you are upgrading from iOS10/11 to 12 the end-user will be required to manually press Next to get past the update screens.
Thank you,
Peter James
