- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Feature Request: Network Groups for Administrator Privileges
Our setup consists of over 100 networks and 30 Admins that require access to different groups of networks. Giving everyone organizations access is not an option. Managing staff changes is a painfully manual process of adding dozens of networks to each administrator.
I am requesting the ability to group networks under Organization > Administrators, and then assign admin privileges to these groups.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Recently I stumbled across a solution... Administrator Groups! Actually it was Network Tags but they function the same. Here's how to set it up...
Create Network Tag:
Go to Network > View all networks
Check all Networks to be included in a group
Click Tag, enter new network tag, click Add option
Click Add
Assign Network Tag to Administrators:
Go to Organization > Administrators
Select the Administrator to be given group access
Click Add access privileges
Select the new network tag from the list
Select the permissions level from the drop down menu
Click Update Admin
Repeat for each additional Administrator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
you can move to using saml
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Create Network Tag:
Click Add
Click Update Admin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi
I have just changed some of the network tags to get a better overview.
then I wanted to correct the setting for admins but keep running into this error messages.
It uses to be straight forward but not this time.
Any idea or shall I raise a case?
Thanks.
John Gudmann
