Failing to enroll a device in Systems Manager
aokullu
Just browsing
Hello am new to SM am trying to Do a enroll a device  but am failing. Giving server error.
7 Replies 7
MarcP
What did you do so far?
Created an profile and you want to download it? Sent the link by mail and then this happens?
RaPo
Dear aokullu,
easiest way is try enrolling using QR Code from within the Network --> Systems Manager --> Devices
But what exactly to you want to do. Have you any authentication Setting activated? Which OS?
Kind regards
Ralf
Raj66
@aokullu Are trying to enroll using MDM profile or Meraki Agent? both of them are pretty easy to enroll in their own ways. For profile installation there are multiple ways to install, you can scan the QR code or go to m.meraki.com and enroll using the network shown on the dashboard. If you are new to Meraki systems manager, please go through this document, it is really helpful, will give you the full picture.
https://documentation.meraki.com/SM/Device_Enrollment/Enrolling_Devices
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
What type of device are you trying to enroll?  Windows 10, iPhone, Android, Apple TV, etc?
aokullu
Just browsing
Hello am using windows 10 OS
aokullu
Just browsing
Hello Philip am enrolling a windows 10 laptop
aokullu
Just browsing
Thanks a lot let me read and revert
