Exporting to CSV from Meraki Dashboard - add Meraki Version
3dHutch
brand new user here to Meraki and CISCO.  very first post after creating my account.
I am exporting to CSV from Meraki Dashboard where our iPads assigned to zoom rooms are kept. Is there a way to get other bits of data in the export that isn't shown in Select Columns dialog.  I am interested in getting Meraki Version number in the export but I don't see a field for this.
Power Bi might be an option, but not at all certain how to access when my credentials are necessary.
2 REPLIES 2
Green_Ghost
When you say Meraki version number, do you mean the current installed version for the Meraki SM app?
You could export from the "SM -> Apps -> SM" page to get this data. Or, you could use an API call.
PaulF
The API is one way.
However, there's a much easier way:
Go to Systems Manager > Software.
Here you'll find all the software installed across every device
In the search, type System  which will bring up Systems Manager, devices and versions
Click CSV and open...
