Endpoint management
meraki2champion
Endpoint management
hello community,
just as meraki insight requires mx as a collector to be able to function so what about this endpoint management where do you feature it is it in access point a switch or in a security appliance?
AjitKumar
Hi
Endpoint Management is an independent solution (EMM / MDM). This is not dependent on MX/MR/MS.
This is a piece of software one needs to install on Windows/Mac/Android and can start managing the device from the Dashboard.
Perhaps one needs to buy licenses depending on the QTY.
Do refer to Meraki Products page for more information.
https://meraki.cisco.com/products/systems-manager
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
2 Replies 2
AjitKumar
Hi
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
SoCalRacer
Also to note it works on iOS/Chrome OS/tvOS
Although independent of the other Meraki solutions it can integrate with them well.
