I have a problem with import students and groups into Education Configuration.
All students and groups are defined in ASM and imported to Meraki System Manager.
After check "Use ASM" (see screenshot) all group are loaded, but without users and user names (only hex ids?).
It is impossible to save configuration, nor changes in group.
This error mesage ocures:
There were errors in saving this configuration:
- One or more errors occurred. No changes have been saved.
- EDU test - You must configure at least one group. Be sure to sync ASM groups before saving this page.
What is wrong? Is it a bug?
Thank you
PS: Manual configuration without "Use ASM" checkbox works fine without problems. But double definition hundreds of students to all classes will be silly.
ASM import
