Dual SIM iOS device management
GWiederCBM
Just browsing
We have a couple of employees that chose to add the SIM card of their company device to their own personal device (both physically and electronically).  Therefore avoiding having to carry two phones.  They must be careful to choose which line they use for personal and work communications, but for the most part it works well.   However, in this configuration, can we implement SM MDM enrollment on the device with dual SIMs?  Will it apply to only the corporate SIM, or the whole device?
Has anyone else encountered this situation?
5 Replies 5
I'm not 100% sure of the answer.
I think if you want to allow this - you might be better off using Android BYOD mode, which partitions the phone into Personal and Work containers.
https://documentation.meraki.com/SM/Deployment_Guides/Android_Enterprise_Deployment_Guide#BYOD_Enrol...
In Android (at least my one), you can then assign SIM1 to the work container, and SIM2 to the Personal container.  It keeps calls, contacts and TXT messages separate from each other.
You can also turn off the work container when not working (which stops all works applications, notifications, etc).
Doh - I just saw you mentioned iOS.
It is my understanding that iOS does not support containers like Android, and has no way to separate work and personal calls and messages.
GWiederCBM
Just browsing
Correct.  Although I do have others who want to use their own personal devices and add our corporate device's SIM to their android device, we have one that has an iPhone with the dual eSIM.  I guess I'm out of luck with that one?  Either I manage their whole personal iPhone (which is probably not going to be acceptable), or I don't manage it at all, and we don't have any control over what that voice line is doing.  I guess we could also just not allow them to transfer the SIM to their device and just force them to carry the corporate android phone in addition to their personal phone.  Again, I'm not sure that solution will be acceptable to this user.
PaulF
Lots to unwrap here...
Firstly, iOS does support containerization in two ways:
1. Managed open in: Embedded within the restrictions payload is the ability to control the management of data from managed to non managed apps and accounts, and vice versa. The segmentation here is very nuanced: It's more akin to keeping personal and enterprise data separate. There's more details here: https://www.youtube.com/watch?v=fPXp6KOjj-Q
2. The second way to achieve this is by using User Enrollment, which is TRUE BYOD.
So, it is possible to support BYOD with SM and iOS
However, Apple has yet to create capabilities that allow for true network usage rules. There are some:
https://support.apple.com/en-gb/guide/deployment/depd912072f4/web
Which SM supports, but I'm guessing that what you'd want to do is specify which bearer that you'd want corporate data to go over: If that's so, Apple doesn't support this (yet)
GWiederCBM
Just browsing
Can you provide me with any links to how I can implement User Enrollment?  I'm not finding much when I search that on the site.
