Disabling iOS System Apps
BlakeRichardson
As the title says I want to know if its possible to disable certain system app's. I am in the process of configuring a bunch of iPads and I want the below disabled
Mail
Tips
Find Friends
Maps
Notes
Reminders
iBooks
Contacts
Find iPhone
Any ideas if I can do this automatically or do I have to manually remove these?
jared_f
@BlakeRichardson You could use the "Do not allow the following apps" restriction to blacklist those specific apps. Also, I recommend you push out the restriction that disallows the following: "Allow removal of system apps (iOS 11.0+)".
1 Reply 1
jared_f
