Chrome Experiement Flags Input Pattern
Vincent_B
Having trouble with the format for disabling new tabs on chrome open when a current one is present. I have searched everywhere for the format to get these options in place. In the value option, is this the correct format correct? Meraki does not give an example anywhere that I could find.
Vincent_B
This is for Chrome Browser Administration.
@CarolineS , I think this might be better in "Mobile Device Management".
@Vincent_B , this problem relates to a configuration you are doing in Cisco Meraki Systems Manager?
Yes, This is the Systems Manager > Settings (Profile List) > :Seleted Profile: >  Managed App Config: Google Chrome Fast and Secure >
