We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Does anyone know how to regain the ability to toggle wifi off & on? The option is greyed out and I cannot find where to change this behavior.
Thanks!
Solved! Go to solution.
Do you enforce the restriction of Force Wi-Fi power on in Profiles?
If so, you will not be able to toggle Wi-Fi on or off and Airplane mode will not turn off Wi-Fi either.
Apparently I was 🙂
I set it that way myself as it has solved a lot of issues of student's Wi-Fi mysteriously not working.
