Can we please disable this?
BlakeRichardson
At a guess it's been 4+ months now of seeing this banner that I cannot get rid of, what makes it worse is it clearly says theres no action needed on my part. I should be able to acknowledge the information and not have it constantly displaying.
This is method of forced notification needs reviewing.
7 Replies 7
KarstenI
Oh yes! Same for "This organization is using a version of Systems Manager that will be retired after February 7, 2024. Visit our SM licensing knowledge base article for more information."
RaphaelL
Not exactly the same but this MX related message is annoying :
KarstenI
And the message when an AP is in a Z ow MXW network!
Meraki_Gwen
Hi @RaphaelL
The alert in your screenshot can be dismissed from your dashboard view by clicking on the x at the top right corner of the yellow box itself.
RaphaelL
Yes but it is either coming back or I have to 'x' it on every 1500 networks that I have 😣
Meraki_Gwen
Hey @BlakeRichardson, thank you so much for the report. I am looking into this for you to find out why this specific alert does not have the x to dismiss. If you wouldn't mind could you please PM me your dashboard link which is still showing the alert? Many customer organizations no longer show this alert. Or if you feel more comfortable, could you open a case to support and send me that case number?
Thank you.
BlakeRichardson
Done thanks.
