- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Best use of tags
I am having an issue where I have an app that is only for ipads and my tags are by group. Generally this works, but the app that is in the group tag also tries to install on iphones in that same group (due to a few other apps that are ok for phones). What's the best way to keep that app from trying to install on a phone?
I created a tag called IpadOnlyApps and assigned this ipad app to that tag. Then I am assigning that tag to all ipad devices. Is that the best way to handle this situation?
Thank you!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Josh3,
Sounds like the way you're handling it would work. I kind of do the opposite thing. I assign a tag to each device (since they can have multiple). So my iPhones get an "iPhone" tag, iPads get an "iPad" tag, etc...
Then I can manage apps/profiles based on Device as well as OS. All Devices with, without, etc...
I don't think there's a real right or wrong way to do it as long as it works for you/your environment and you're ok with how it's managed.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Josh3,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Josh3 we use three different category of tags. One for device type i.e. iPad, iPhone, Laptop Desktop. Second is if its a "Staff" device or a "shared" device. Then lastly we have department tags i.e. IT, healthandsafety, maintenance, finance..
With having this many you can specify tagging that is broad or be quite specific.
