BYOD POSTURE CHECKING FOR CLIENT VPN... (WHEN?)
Doke
Can you guys get to work on making a posture checking on at least for win 10 and with or without agent
7 Replies 7
T1
Isn't that what policies are for? Mandatory running apps tickbox?
Doke
I dunno, is it? do you think that will check CLIENT VPN systems before they are allowed access to VPN or just the LAN?
BrechtSchamp
Are you using Meraki Systems Manager?
Doke
yes, it is the legacy "grandfathered" version so not as feature rich from what i hear.
BrechtSchamp
I'm afraid it won't work with legacy SM.
This document describes how to push VPN settings to devices tagged with "vpn" and passing the compliancy check. But it clearly states that it's not available to Legacy SM users:
https://documentation.meraki.com/SM/Tags_and_Policies/Security_Policies_in_Systems_Manager#Using_Sec...
Doke
ohhhhhhhhhh....
Doke
So i cant even tag my VPN clients without SM paid? cause unless im not doing something right, i dont see the ability to tag the client devices.
