Apple TV "invalid certificate" error when setting up
gb111
Hi, I am having trouble integrating an Apple TV 4K in Meraki. After preparing it in Apple Configurator 2.7, once I give it the command to load from the MDM on the Apple TV itself, it gives the error of "invalid certificate".
Does anyone have a solution/suggestion for this?
gb111
My bad, did not notice that the free trial ended. Everything normal, just misunderstood that the one with the limited amount of devices was still used.
Suggestion: for those trying Meraki SM, when the first month ends maybe put a red alert at the top saying that there are no licenses available or free trial ended.
7 Replies 7
jared_f
Are you enrolling your Apple TV into DEP or just using the manual enrollment payload?
Manual enrollment with supervision activated.
gb111
This is the screen after choosing setup with remote configuration.
jared_f
Are you using authentication? That may be causing the problem. Also, make sure you have the Meraki certificates selected when enrolling devices. If not, they won’t ping the server resulting in errors.
gb111
aws_architect
Did you still had the problem after putting license ?
We have the same on 5 apple tv and we have a lot of license.
I actually moved away from Meraki for now.
With manageengine everything worked.
