Apple TV being incorrectly auto-tagged as a Mac
Javier323
I've enrolled an Apple TV into DEP and MDM via Apple Configurator, but when it appears in the Meraki Dashboard, it has been auto-tagged with a device type of Mac.
Some of my settings use the auto-tags to determine which profiles get pushed to what devices, so the Apple TV is now being pushed macOS profiles, causing broken app icons to appear on the Home Screen for apps that aren't supported on tvOS and other difficulties.
Has anyone else encountered this? Or been able to correct it?
ConnorL
Can you open a case with Meraki Support regarding this, please? I'm seeing a few instances of this.
ConnorL
Quick update, this has been reported to Engineering. As soon as I get any updates I'll bump this thread.
Javier323
Hi @ConnorL, just checking, have there been any updates on this one? (Or maybe a recommended workaround.) Thanks!
Javier323
Just as an update, this issue is continuing to occur.
