Apple MDM Certificate Renewal
AmandaSWA
Hello!
I am in the process of reviewing my MDM Certificate and have been following these directions (https://documentation.meraki.com/SM/Device_Enrollment/Apple_MDM_Push_Certificate). However I am getting the attached error message and I can't figure out what else to do. I am logged in with the same Apple ID, and I have double and triple checked that I am following the steps exactly. Can anyone lend me some advice?
Adam
Well I just downloaded a CSR from my dashboard and it appears to look the same as yours.  So your next step may be support to make sure there isn't an issue with the CSR export.
5 Replies 5
Adam
Error would seem to indicate an issue with the CSR.  Are you the copy of the CSR you downloaded from the Meraki dashboard isn't corrupt?  Maybe after you've downloaded the CSR try opening it in notepad.  The content of the file should look something like this with different hash information in the middle.
-----BEGIN CERTIFICATE REQUEST-----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-----END CERTIFICATE REQUEST-----
AmandaSWA
When I open it in TextEdit (I'm on a Mac) it looks like below.. How do I fix it if it's incorrect?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Adam
Adam
I see you marked the thread as solved.  Were you able to find a solution or just moving on to support?
AmandaSWA
I went back through the same steps I did 4 times yesterday and it just worked this time. So, good to go! 🙂
