We have been using SM for a few years to manage Apple devices. I like that we are able to enroll the devices without the need for an Apple ID.
We are getting ready to deploy Android devices for the first time and I am wondering if there is a way to enroll them without the need for a google account for each device.
Thank you,
Gary
Solved! Go to solution.
>account that belongs to the bound Google Domain
There might be some confusion here. It's the same on both platforms.
For us, we use Office 365, so use Office 365 authentication. You can use some other local authentication. It doesn't need to be a Google Account.
You can choose to use no authentication at all, but I don't recommend that. Then it doesn't create a owner->device relationship.
You need to enroll them on "Device Owner" mode.
https://documentation.meraki.com/SM/Deployment_Guides/Android_Enterprise_Deployment_Guide
Thanks Philip, we want to go with the Device Owner option using a Google Managed Domain. When I look at the deployment guide it states that I need to sign in with an account that belongs to the bound Google Domain. That’s what I want to avoid if possible. I looked at the zero-touch enrollment option but unfortunately our tablets are Samsungs.
Is there a way to eliminate the need for a Google account? If not can it be the same account for all tablets or do they have to be unique?
Ok that makes sense Philip. Thanks very much for your time!
