Android kiosk mode layout
jcavazos
Just browsing
Hello
I am in need of some guidance on how or if it can be done, I would like to arrange the screen (in kiosk mode) to show the apps in a certain layout as they currently are not so organized.
Typically in Kiosk mode there is no "home screen".  The device runs a single app.
https://documentation.meraki.com/SM/Profiles_and_Settings/Android_Kiosk_Mode_in_Systems_Manager
jcavazos
Just browsing
Thank for the replay, PhilipDAth
The current configuration is Kisko mode in MultiApp w/ list of allowed apps, the question is more on the layout of the apps that the user gets when they are presented when the screen in Kisko mode. Would like to arrange them in a certain order for easy of usability.
PaulF
Meraki Employee All-Star
Hi.
So, the SM app doesn't support any form of layout for the various Kiosk apps you may be using.
