Android Apps Disappear
DavidF
Just browsing
Hello All
When I add apps and push them down to the Samsung Tab A they install fine then randomly in the managed apps screen they disapear and reinstall . Its not all apps  but a few I have noticed is google maps , samsung email , chrome
all apps were downloaded from the play store.
I also will remove any internet shortcuts on the home screen.
Thank you for you help
David
4 REPLIES 4
merakichamp
@DavidF try to check your settings on  restrictions tab check if you have put to show or hide your apps
Hi merakichamp
I do not see that option on my screen.
merakichamp
@DavidF  you just needed to scroll down more and you will see it just before Device functionality
i have shared my screens just to show you  you  really need to scroll down
Hi merakichamp
It look like that option is only for IOS not android.
I was able to add KNOX and allow all the apps and it look like is is working
Thank you for your time and help
