Andriod screen timeout
S4naco
Is there a way to set the screen timeout for Android devices? The only options available after enrolling in SM are 10 seconds, 30 seconds and 1 minute. The Screen Timeout menu says that "Other options (Not shown here) have been turned off by your administrator" but I haven't done it so it must be a default setting. Some of our end users need more time or keep the screen on until they lock the device or press the power button.
Thanks in advance.
BlakeRichardson
@S4naco  Sorry for the late reply but Android options on Meraki SM are a bit limited compared to iOS options. I've checked and I don't see any where in SM you can set screen timeout.
2 Replies 2
BlakeRichardson
S4naco
No worries, thanks a lot for checking. I appreciate your time and help.
