Adding VPP to MDM Settings Missing
Kennyboyraven
I'm trying to update the link to ASM. In the past you downloaded the token from Settings > Apps and Books. This is no longer around, there is not settings option! Instead there is your name, which you can click to get a preferences section.
In here there is the MDM setup, which I have already used for the ADE link. If I try to use the same token I downloaded I get a message (in Meraki) that the server token cannot be blank.
Pulling my hair out here, any help appreciated. 🙂
PaulF
Meraki Employee All-Star
I'm with you on this:
ADE Token location:
VPP token location (this looks to have moved recently)
The two tokens are NOT the same.... and not interchangeable.
2 Replies 2
PaulF
ADE Token location:
Kennyboyraven
Thanks so much! 😎
