Accidentally removed Network from Change Network
mischief_queen
I didn't realise what I was doing and removed the device from this option.
Can someone please let me know if there is any way to find the device and add it back?
2 Replies 2
You can check in Organization Monitor > Change Log all the changes made in the panel.
BlakeRichardson
If you have removed the device from your MDM you will need the manually add it back in, this will require access to the device.
If the device was previously enrolled using ADE you may need to erase the device to get all of the functionality to work.
