ADE Status is stuck in Assigned
ManorIT
I have several devices with ADE Status stuck in Assigned.  Others show pushed.  It doesn't seem to be a device specific thing and the devices all have the same profiles, etc.
5 Replies 5
BlakeRichardson
Have you tried forcing a full sync via Systems Manager > Manage > ADE
ManorIT
Yes we have.  They just remain in Assigned.
BlakeRichardson
Have you signed into you ADE as the terms and conditions may have been updated and you need to agree to the new terms before changes take place.
vivification
I have the same problem, I suspect it is to do with devices that were not purchased directly from the Apple Business Store, but rather manually sync/added via Configuration Manager.
I am not sure if it is making any difference/impact though?
LevelUp
I am just getting ADE setup and testing with an iPhone I enrolled with Apple Configurator.  It shows up in the Meraki dashboard with ADE Status "Assigned".  Did you ever get this working for you and if so, what steps did you take?  Thanks!
