We recently upgraded this community because the old network lacked a decent wifi signal throughout the building. The biggest challenge in this site was that we had two floors and we had to do some adjusting with the wifi due to bleed over from the other floor but installing MR 36 AP's really helped because they do most of the radio and power settings out of the box.
We used 3
32 MR 36 AP's
1 MX 80 Router
3 MS 225 Switches
10GB SFP's Meraki
40 GB Stacking cables
2 APC 1500RM2U UPS with Nic Cards
In the future we hope to install a second circuit and use the SD Wan and we will upgrade the MX to the MX84.
IDF
MDF
Comments
Want to join the conversation? Log in with your Cisco ID to comment. If you don't have one, sign up—it's quick and easy.
