meraki go app problems
Taka2000
problems
1.APP CRASHES
The app crashes when you set a time limit on the meraki go app
When will it be fixed?
2.web blocking
Even if I block the web, it will pass through. Specifically, my child is playing on discord.com, so I blocked him, but he can still access it normally and can download it. For what reason can it be used? I really feel that their technical ability has declined. The old CISCO engineers were truly amazing. Are kindergarteners protecting them now?
2 Replies 2
Taka2000
The explanation screen for web blocking is also very poor. There is no picture of the explanation screen. Or are they blocking me with the blocking function?
https://documentation.meraki.com/%E6%97%A5%E6%9C%AC%E8%AA%9E/Go/Access_Control_jp/go_web_blocking_jp
ArtMarshall
Meraki Alumni (Retired)
Hi Taka200, can you share more information on what you mean by setting a time limit?
