how to Block Teamviewer
Ravindhar
I Want block Teamviewer Application in my network, Please Advise how to block in meraki.
Regards,
Ravindhar.
1 Reply 1
JamesMW
Meraki Go Team
Meraki Go Team
@Ravindhar - you can set usage limits to block or limit applications by category from the applications screen or by using the set usage option on your desired network. While you can block a specific website or a specific device, currently you can only block or limit applications by category not by specific application.
James
James Wilson
Cisco Meraki
