I have a question concerning the status for clients. As you can see below, the Radio Band is reporting 2.4Ghz, but the Signal is reporting channel 149, 5 Ghz. Could someone explain what this means? Is it using 2.4Ghz as the radio band suggests, or is it using 5Ghz as the Signal suggests?
