Turn off 2.4ghz
tacotaco
Turn off 2.4ghz
For the GR10 or GR60, is it possible to create a SSID wifi network with only 5ghz?
Lee
Yes it is possible. After setting up a network/SSID, select it from the networks tab. You then go to Settings>Advanced Settings>Radio Settings, you can configure the network to run in dual mode, 5GHz only or 2.4 GHz only.
1 Reply 1
Lee
